Comment: 2002 Trip - Kimberley & Kakadu. Part 4 –Windjana Gorge to Wyndham on t
Submitted: Monday, Nov 22, 2010 at 14:38
ExplorOz - David & Michelle
John - I am working on that. But just for you here are some text tricks you can use:
{SH}Sub Heading{/SH}
{MH}Minor Heading{/MH}
{BQ}Block Quote - basically indented paragraph{/BQ}
You can also do lists with the following:
{UL}{LI}List Item 1{\LI}
{LI}List Item 2{/LI}{/UL}
Of course convert the {} into [] - I cannot put the square ones it else they will convert.
Only rule is to make 100% sure you close what you open with the / version else the site layout may go wrong. I am as I mention working on a much better editor and more commands but all good things do take time. Have a play with the above as these will always be supported.
David
