I cannot print some posting with netscape4.7?
Submitted: Wednesday, May 15, 2002 at 00:00
ThreadID: 1141 Views:2132 Replies:2 FollowUps:2
Hello --
This is not the first time it happened.
On about 5% of the posting I receive an fatal error and this error
terminate Nescape 4.7 (Communicator) when I try to print some posting
from this forum.
Has any one find a way to stop this with Communicator 4.7?
I do not like using IE5.5. (too many rubbish coming through)
Guy
NETSCAPE caused an invalid page fault in
module NETSCAPE.EXE at 0177:006a7b05.
Registers:
EAX=000016ba CS=0177 EIP=006a7b05 EFLGS=00010246
EBX=00000000 SS=017f ESP=00b4f648 EBP=00b4f6ac
ECX=000016ca DS=017f ESI=00c21b6c FS=4ec7
EDX=182e688e ES=017f EDI=0000004b GS=0000
Bytes at CS:EIP:
8b 43 04 8b 4d 24 ff 75 30 ff 75 2c 57 3b c1 7f
Stack dump:
00b4f7b0 00d73890 0080e0e8 81c277a0 00000006 00000184 00b4f69c 02ceb39c 00000028 0000001e 0000000b 00180001 00000000 00000000 00000000 00000000
Reply By: ExplorOz Team - David - Wednesday, May 15, 2002 at 00:00
Guy,I fully tested the forum using 4.7 Netscape and I cannot find any fault with the system at all. How are you trying to print the pages are you selecting the print icon at the bottom right hand side of the screen or just hiting the print on the task bar/menu? Also I am interested in what you mean about IE has to much rubbish coming through?Having asked these questions and reading the page fault message I suspect that you either have a browser corruption or you are trying to just print the page in its current format. Do you have the media available and can you reinstall the program? Try using the print option at the bottom of the screen. Let me know what happens!David
AnswerID: 3579
Reply By: jono - Friday, May 17, 2002 at 00:00
David,
I have also had the odd printing problem in IE5, but only when i press the 'print' shortcut on the toolbar. when i go through the file menu, then to print, there is no problem.
Also when printing, the header information doesn't come out properly, sometimes the drop down lists appear over the top of the title in the printed document. not a major problem i know, but i'm just wondering if it is something at my end or due to ExplorOz setup?
AnswerID: 3612
Follow Up By: Exploroz Team - David - Friday, May 17, 2002 at 00:00
Jono,I think you have missed the fact that we have a Print option built-in to all the ExplorOz pages.
It takes away the java script and dhtml components that can cause problems from printing direct from the browser print options.
Look at the bottom of the page - far right and use our print option and post a reply confirming results. Thanks.
FollowupID: 1466
Follow Up By: Jono - Friday, May 17, 2002 at 00:00
David,
Cheers for the advice, it seems i had overlooked the print function you have provided, but i tried it and had no problems so thanks for that. i think it would help if this forum wasn't so good, because then i would have more time to look around the pages more. But because it is so good, i like reading all the questions that are posted and learning as much as possible from them. This creates a problem for me as i can only get on the net at work and so i have to sneak onto ExplorOz when the boss isn't looking, so my time is usually cut short. Anyway, thanks for the help, great forum. Cheers Jono.
FollowupID: 1467
