Comment: Using the 4psi Tyre Inflation Rule
Submitted: Sunday, Oct 21, 2012 at 14:36
Lee G1
The gas law you should be using here is Boyles. Any calculations done would unlikely be accurate as you need to have a constant volume to work with which a tyre isnt. As a tyre heats up it will stretch therefore increasing the volume thus decreasing the pressure how much is hard to say but it it likely that the actual pressure change is going to be minimal
