Comment: Bush Welding - Video
Submitted: Friday, Mar 16, 2012 at 20:54
Member - bungarra (WA)
Hi Mick
the video is a great idea and keeping short and simple is great. The only issue I have is that I use the electrode on the negative - and the job (work as the + ). This gives a smoother weld for DC. Just to make certain what I had in mind was right I have googled a couple of battery welding with DC and the two sites i checked also use the electrode on the -
They both work because at the end of the day you are causing a short curcuit and melting the rod but negative on the electrode gives a smoother weld.
Graeme
