Comment: Burton's Perth to Cape York Darwin to Kununurra 14 -19 June 2011 Day 76
Submitted: Wednesday, Jun 20, 2012 at 19:41
Graham & Lynne
Just a thought you may have mud caked around outside of your oxygen sensors on the exhaust.this will stop the oxygen sensors get a reference oxygen read from the outside air.So need to pressure clean around the outside of the sensor and its wiring.
Thanks Graham
Reply By: Mike & Amanda - Wednesday, Mar 04, 2015 at 01:14
It turned out to be that the
fuel pump is fitted inside the
fuel tank and is wrapped in a gauze strainer. This was choc a block with red dust and varnish from Opal
fuel! Thanks for your advice - we eventually broke down on the way to
Cape Leveque and called a tow truck!
548514
