Comment: Cape York
Submitted: Monday, Sep 02, 2013 at 14:56
ThreadID: 116023 Views:1425 Replies:0 FollowUps:0
Hi Willi, yes. The idea is that you type the text into your blog separately and you click to add the photos into the place you want them - do you look at other people's blogs? You'll see a mix of text and photos. Nothing to lose by giving it a go. You can't break it. You can delete it. Just be brave and have a go ;) That's if you use the computer to write your blog.
The other way to make a blog published is to do it from email - write an email with pics (attachments) in it and send to blogs@exploroz.com (make sure you send from the email account that is linked to your member profile so the server detects its you!). You must ensure the email you send has a subject line - this will become the title of your blog. The system will just automatically put the pics at the end. You can always open the blog later and click the button to edit the name/description of the photos and add more info there if you like.
Hope that helps, Michelle
Michelle Martin
Marketing & Customer Support
