Comment: Kimberley Karavan Lithium Battery Conversion
Submitted: Monday, Dec 15, 2014 at 10:18
Macquarie
Thanks Frank P, all very informative and clears up some misconceptions I had on the product. I shall investigate LFP use in my Aussie Swag camper when the current AGM's give up the ghost.
Reply By: Frank P (NSW) - Wednesday, Mar 04, 2015 at 01:26
Hi David,
Thanks for your comment.
Mate, they are fantastic! Once you try them you'll wonder why you used lead-acid for so long. You'll never go back, I can assure you. I'm extremely happy with the supplier I used. He has expanded his range so you should be able to find a capacity/physical size combo to suit your application.
Frank
549323
