Triton Headlights
Submitted: Tuesday, Mar 24, 2015 at 19:54
Life Member-Doug T NSW
My Daughter just discovered low beam is not working on her 2007 V6 Triton, High beam is OK , I am suspecting both low beams in the bulbs have blown, she always drives on low during daylight hours. Or is there a separate fuse for low beam,
Reply By: Bob Y. - Qld - Tuesday, Mar 24, 2015 at 21:38
Don't know about a low beam fuse in the Triton, Doug, but did have both low beam filaments blow in an 80 series wagon once. Ha ha, bad timing, we were just about to head into
Brisbane late afternoon. Luckily found an auto sparkie still open. :-)
Hope the rear of the headlights are easy to get too?
551567
Reply By: Notso - Wednesday, Mar 25, 2015 at 08:53
This is an extract from the manual.
COMMENTS ON TROUBLE SYMPTOM
If the low-beam headlamps do not illuminate, the headlamp switch input circuit, the headlamp relay (LO) or the ETACS-ECU may be defective.
PROBABLE CAUSES
Malfunction of the headlamp relay (LO)
Malfunction of the column switch
Malfunction of the ETACS-ECU
Damaged harness wires and connectors
551575
Reply By: Life Member-Doug T NSW - Thursday, Mar 26, 2015 at 01:22
Thanks for the re[lies, problem is fixed, 2 new bulbs did the trick.
551624
