Fridge issues
Submitted: Friday, Apr 03, 2015 at 10:27
ThreadID: 117337 Views:2771 Replies:1 FollowUps:2
Good morning everybody have a problem with my fridge,i woke up this mornind and the fridge 240lt Nova Kool 12volt compressor fridge had defrosted, the freezer is running but the fridge wont work,and people out there have any idea where i can look to fix the problem.
Humpback
Reply By: HKB Electronics - Friday, Apr 03, 2015 at 10:48
When you write the freezer is running but the fridge won't work do you meant the compressor is running but not cooling, if so then the unit has most likely lost its gas charge due to a leak?
AnswerID: 551962
Follow Up By: humpback - Friday, Apr 03, 2015 at 13:43
Hi HKB Thank you for your feedback,the fridge went up to 11c and after about 4hrs the motor started back up and now it is running at 4c,dont know what the problem was but it is working.
Humpback
FollowupID: 837506
Follow Up By: daz (SA) - Saturday, Apr 04, 2015 at 12:26
Is this fridge running on 12 volt My guess if it is that the battery voltage dropped too low and therefore would not let the compressor kick in until the battery received a boost. Do you have solar panels which charged your battery in the 4 hours
Cheers Daz
FollowupID: 837547
