replace stop tail turn globes with leds 80 series
Submitted: Saturday, Apr 04, 2015 at 20:38
Member - Mal B
looking to change my globes to led is it with it and what cost thanks mal
Reply By: Simon C - Saturday, Apr 04, 2015 at 23:33
No idea...but check if you need added resistors...or the indicators may flash like mad. not enough resistance in the globes to make the indicators work correctly
552018
Reply By: Member - Noah273 - Sunday, Apr 05, 2015 at 02:56
Reply By: GarryR - Sunday, Apr 05, 2015 at 07:37
also check with your brake lights. Your cruiser control may not work if there is not enough resistance, you may need to install a ballast block on each light to operate correctly. I,ve experienced this on my work vechile
552021
Follow Up By: Bob Y. - Qld - Monday, Apr 06, 2015 at 18:58
What Garry said..........
Fitted LED globes to stop/tail lamps on our 80 series. Seemed okay till we wanted to use the cruise with lights on......cruise wouldn't work.
Also the light pattern was more concentrated in centre of the lens, so probably wasn't as efficient as the normal globe..... nor as safe?
Rather have the cruise so ditched them. Probably have a place in the front parkers, where the beam is whiter, and brighter.
837622
Reply By: Crusier 91 - Sunday, Apr 05, 2015 at 07:48
You can purchase the whole assembly for $140 a pair on fleebay delivered. Just plug in and bolt on.
or
new aftermarket globe assembly for under $60 a pair delivered. I went down this track to replace the old cracked and weathered units, they fit and come with new globes
552022
Reply By: Nomadic Navara - Sunday, Apr 05, 2015 at 23:48
If you just replace the globes with LED plug in devices then you render the lamp fittings non ADR compliant. The only light sources that will give you the correct spread of light in the fittings are those that conform to ADR 51.
You need to replace the complete light assembly with an ADR compliant unit.
552042
Reply By: Member - Mal B - Tuesday, Apr 07, 2015 at 20:32
Thanks it sounded like a good idea at the time not shore now, maybe leave what has been ok for 22+years as is, thanks for your thoughts and advice travel safe Mal B.
552117
