rough idle
Submitted: Thursday, Apr 01, 2004 at 22:02
Pappas
G,day guys. got an 80 series which is idling a bit rough, i should mention its duel
fuel. Once the engine is at proper operating temperature its a lot less noticible, under accelaration its okay, only when coming to a halt and stopped but worse when motor is cold, Has anyone had any experiance with this, Is it a duel
fuel thing that needs adjusting. I just hope its nothing to serious that a cheap bottle of nulon won,t fix, ha ha.
Reply By: Member - Toonfish - Thursday, Apr 01, 2004 at 23:26
Not sure if you have the 2 f motor but diamond was telling me tonight about a motor rebuild he is currently doing on a 2f 80 series and mentioned they often damage cams!
hate to alarm you but sounded similair to your drama .
only passing on recent knowledge to me but cam
shop sells plenty of cams for that motor on a daily basis too!
reason being only 4 bearing calmps for a 6 cylinder motor??????
many 4 cyl have 5!
just an observation , hope im wrong as it sounded costly
52892
Follow Up By: raybates - Friday, Apr 02, 2004 at 00:17
Hi I have an 80 series on gas. It runs rough if the
water level gets too low causing the gas not to vapurise properly.
314685
Reply By: Simon C - Friday, Apr 02, 2004 at 08:45
Check air clean inlet pipe from Air cleaner to Manifold. My perished underneath from the heat from the exhaust (Can not see it untill you remove pipe) It sucks in dirty air, and causes one of the sensors close to the Air cleaner not to read the correct air flow. Replaced
mine, and engine ran a lot smoother When I purchased from Toyota....guy said "Another one !!!!" Worth checking all 4.5 Litre Petrols for this problem.
52907
Reply By: RenoRXGQ - Friday, Apr 02, 2004 at 13:04
2nd the extra air being sucked in from somewhere. I have a GQ on dual
fuel and had the clips on the air box broken off and it idled like a dog on gas. Air box fixed and no probs. I guess check all hoses for cracks etc.
52934
Reply By: Chris (W.A.) - Friday, Apr 02, 2004 at 18:12
There is also a little rubber hose under the intake manifold on the passenger side of vehicle. My car wasn't running the best, I found that it had come off. It runs from the carbon cannister across to just under the manifold. Also check
fuel filter and dizzy cap for splits or other wearing.
52969
