Battery overcharge
Submitted: Monday, Apr 20, 2015 at 10:48
rare
I have a Ctek DC -DC charger as
well as battery monitoring system with audible alarms. The system has started alerting me to over charging? Is this possible with Ctek? IE: Can they over charge?
Reply By: oldtrack123 - Monday, Apr 20, 2015 at 10:56
HI
Very unlikely that the Dc Dc charger is overcharging
But you may be getting false readings ,check ALL connections are clean & tight Especially battery terminals
PeterQ
552713
Follow Up By: rare - Monday, Apr 20, 2015 at 12:40
Yeah,
I hoping to do that next weekend. I'm also need to relocate the Ctek anyway, It will be about a metre from the battery its charging but I don't think that will matter so longg as I use thicker cabeling
838381
Reply By: Member - Jim B8 - Monday, Apr 20, 2015 at 14:12
I had to relocate
mine from under the bonnet to inside the canopy, as I had heat faults coming up. All good since Ctek 250D
552715
Reply By: gbc - Monday, Apr 20, 2015 at 18:40
Being a 5 odd stage charger, the ctec will probably spike to 'overcharge' levels during desulphation which is quite normal and would result in your other monitor going berserk. Check your user guide for how they work.
552725
Reply By: Member - Phil G (SA) - Monday, Apr 20, 2015 at 22:05
Where is the Ctek installed? Where is the battery installed and where is the temp probe positioned?
Yes you can overcharge with a D250S. Usually happens if the temp probe has not been placed next to the battery so temp compensation doesn't occur.
552736
