Barrett 250
Submitted: Friday, Apr 24, 2015 at 16:50
Member - William B (The Shire)
Hello,
Can some one please tell me the the dimensions of the Barrett 250 remote head.
I'm trying to work out where to fit it into my Prado 120.
Thanks in advance.
William
Reply By: Racey - Friday, Apr 24, 2015 at 17:12
Try Mr Google.
552888
Reply By: get outmore - Friday, Apr 24, 2015 at 19:00
darn if i was home id measure it up... definitly not small - ive screwed them into the transmision tunnels in the 80 and the 78
if your after a guess id say 20cm x12cmx10cm
im suspecting i may even be a bit conservative
552892
Reply By: MEMBER - Darian, SA - Friday, Apr 24, 2015 at 20:58
Can't help with the size, but if you don't find a space for it, keep in mind the "Ram windscreen suction mount system"...you can rest the head on your dash (safe viewing up there too, while mobile) ....and the suction mounts are very secure...used it with my B550/950 head for ages.
552896
Follow Up By: Member - bungarra (WA) - Friday, Apr 24, 2015 at 21:07
Hi Darian
Are you able to point me in the right direction (model #) for a Barrett 950 remote head please?
The website has significant types but I am unable to see a specific one suitable for the 950
Sorry to hijack OP thread
838623
Follow Up By: MEMBER - Darian, SA - Friday, Apr 24, 2015 at 22:07
Message sent to Bungarra.
838624
Follow Up By: Member - William B (The Shire) - Sunday, Apr 26, 2015 at 17:24
Hi Darian,
I have a Ram mount for my Spot and am very happy with it.
Could you also point me in the right direction, because like Bungarra I couldn't find the correct mount on their site.
William
838702
Follow Up By: MEMBER - Darian, SA - Sunday, Apr 26, 2015 at 18:22
I haven't seen an actual Ram speaker mount for the application in question....(I haven't searched though :-)....I just used the existing plain and simple Barrett flat metal wrap-around speaker bracket. If there isn't one for the 250 head, making one would be simple....bolting it to the Ram ball base is no issue.
838704
Reply By: Member - Errol (York WA) - Saturday, Apr 25, 2015 at 22:27
Dunno about a remote head, but I can give you the dimensions of a standed 250. Should'nt be a lot diferent. I'll measure it tomorrow as I have second one sitting on my desk in the man
cave. Errol
552933
Follow Up By: Member - Errol (York WA) - Sunday, Apr 26, 2015 at 21:21
Sorry that took so long, been tied up all day. Here is the size. 250mm wide (across the front), 350mm long ( this is including the nobs), and 95mm high. You also have to include the cradle witch I haven't here. With a remote head, should be a bit shorter I think, but the same width and the same height. Hope this helps. Cheers Errol (
Mobil 2409)
838713
Reply By: get outmore - Tuesday, Apr 28, 2015 at 14:33
Ok measured but not exact
163mmx80x60mm
This does not include knobs switches which add another 10mm approx
or the big connection to the rear for both power and speaker.. you would need about 150mm for depth to accomadate
these are NOT made for in dash mountings hence why ive never or ever seen them mounted as such
553020
Follow Up By: Member - William B (The Shire) - Tuesday, Apr 28, 2015 at 15:20
Thanks for that,
Thats a decent size to have to match up somewhere.
At least now I have a idea of the size to start looking around.
William
838770
Reply By: get outmore - Tuesday, Apr 28, 2015 at 16:13
As I said ive had an 80 and now a 78 and have mounted them on the transmission tunnel just out of the way of gearstick operation.
553024
