Landcruiser 105 - Bullbar fitting - Bolt size
Submitted: Tuesday, Apr 28, 2015 at 02:47
ThreadID: 117647 Views:6250 Replies:2 FollowUps:7
Hi ;
Anyone know the bolt size to fit a Toyota genuine alloy bar on a Landcruiser 105 ? And/or what washers etc are needed?
Thanks if you can help,
Reply By: TomH - Tuesday, Apr 28, 2015 at 07:32
If its a new bar they will come with the fitting kit . If its second hand make sure you get the kit with it.
I bought a second hand airbag compliant one for a 100ser and it didnt have the kit and cost me nearly $200 from Toyota
AnswerID: 553015
Follow Up By: Faysie - Monday, May 04, 2015 at 14:48
Thanks, its second hand and unfortunately no fitting kit. It has the brackets but no bolts.
The bloke who I got bullbar off said the bolt size was M12 but was unsure of thread size.
FollowupID: 839103
Follow Up By: TomH - Monday, May 04, 2015 at 14:57
If you have a towbar they are the same Look at them
FollowupID: 839104
Follow Up By: TomH - Monday, May 04, 2015 at 14:59
Forgot If its an airbag compliant one you MUST use the correct fitting kit. There are different ones for non airbag and airbag ones
There was a sticker on the inside of mine with part number etc.
FollowupID: 839105
Follow Up By: Faysie - Monday, May 04, 2015 at 14:59
Thanks for the tip :)
Unfortunately I have a tow bar I have to mount as well, and it doesn't have bolts either ! I will trial and error on the tow bar and go from there :)
FollowupID: 839106
Follow Up By: TomH - Monday, May 04, 2015 at 16:18
Take it down to an engineering place and try some They are a reasonably fine thread from what I remember
FollowupID: 839115
Reply By: Faysie - Friday, May 08, 2015 at 11:56
They are M12 x 35mm x 1.25
AnswerID: 553441
Follow Up By: Peter_n_Margaret - Friday, May 08, 2015 at 12:28
Grade 8-8 or better?
OKA196 Motorhome
FollowupID: 839299
Follow Up By: Faysie - Friday, May 08, 2015 at 12:35
Yes, 8.8 or better
FollowupID: 839300
