winch kit
Submitted: Sunday, Jun 14, 2015 at 23:51
ThreadID: 119183 Views:3776 Replies:4 FollowUps:1
Can i add a winch to my 2002 toyota prado bullbar , just a toyota bullbar
Reply By: Member - ACD 1 - Monday, Jun 15, 2015 at 00:04
Hi Mark
Your bar needs to be winch compatible.
Are the mounting brackets strong enough to stop the bar being pulled off or the winch being pulled out of the bar.
Does the bar have a mounting point for the winch, a square cut out in the face of the bar for the fair lead or roller block, holes in the top to access the clutch.
Someone may just tell you to cut holes, but I would hate to be around when you use it.
Anthony
AnswerID: 555971
Reply By: Peter_n_Margaret - Monday, Jun 15, 2015 at 03:10
You don't need a bull bar to have a winch, just something strong enough to attach it to.
In fact it does not need to be permanently mounted at all.
This is a Warn 16.5Ti.
OKA196 Motorhome
AnswerID: 555972
Follow Up By: vk1dx - Monday, Jun 15, 2015 at 08:46
This is a bit rough for me. I couldn't even carry the winch. Then where do you store it.
Not a bad idea if you need to use if from different locations/directions.
FollowupID: 842062
Reply By: Shaker - Monday, Jun 15, 2015 at 08:25
If it is the Toyota Sovereign bullbar, I believe that there is a winch cradle kit available.
You can double check over at PradoPoint or simply ring dealer spare parts dept!
AnswerID: 555979
Reply By: Pradobob - Tuesday, Jun 16, 2015 at 12:21
You need a winch cradle. Part number is: PZQ29602WC Probably well over $200 by now.
AnswerID: 556029
