'fridge shelves
Submitted: Saturday, Jun 27, 2015 at 17:10
LYNETTE L
What is the secret/challenge in removing the shelves in a Caravan Electrolux RM 2339 'fridge please.
Reply By: Member - Teago - Saturday, Jun 27, 2015 at 17:12
Hi suggest you google dometic. But I suggest like most it will be slide upwards Cheers
556414
Follow Up By: LYNETTE L - Thursday, Jul 02, 2015 at 16:32
10Q this was perfect, I was just concerned initially about prying the little slide on the clip. Worked
well. cheers, Lynette
842815
Reply By: Ozhumvee - Saturday, Jun 27, 2015 at 18:43
Usually the door has to be opened fully
well past 90 degrees to allow the shelves to be slid forward and out.
If your van installation doesn't allow the door to be opened enough then the door may have to be removed.
556416
Follow Up By: LYNETTE L - Thursday, Jul 02, 2015 at 16:33
842816
Reply By: Member - Keith C (NSW) - Saturday, Jun 27, 2015 at 20:07
Hi Lynette, the shelves are held in by small clips in the shelf slides, if you look carefully you will see them, just prise them off and remove shelf, good luck. Keith
556419
842814
