Thursday, Jul 09, 2015 at 20:05
HI Chris
Try this ink for the manual
www.seatronic.no/pdf/Powersaver/powersaver_lader_eng.pdf
You can then check the settings ,
Apart from simulating the load characteristics of a battery connected to the Charger, the easiest way to check it is on a battery
using a volt & amp meter &observing to ensure it goes through ALL stages @ the correct voltages & time
Although those batterries are probably stuffed they may still be good enough to do those checks
843092
