Drumming noise in Landrover
Submitted: Friday, May 24, 2002 at 00:00
ThreadID: 1195 Views:2017 Replies:9 FollowUps:3
My Landrover Discovery 1996 TDi Auto has developed a rythmic drumming noise, most noticeable when highway cruising 90 -100kph when under load. Ease the pedal a fraction and it stops. Has been doing it for a while now off and on but seems to be getting worse - even my wife comments on it. Has anybody had this sort of experience, or any suggestions as to the problem?
Reply By: alreadttaken69 - Friday, May 24, 2002 at 00:00
probably its that toyota bleep box following you, ay goran.
AnswerID: 3806
Reply By: john - Friday, May 24, 2002 at 00:00
sounds simular to a universal joint on a tail shaft. if it is it wil star vibrating soon.
could also be a wheel bearing. turn the stering wheel from side to side while doing about 60 k's . if it comes and goes thats it.
AnswerID: 3809
Reply By: Savvas - Saturday, May 25, 2002 at 00:00
While this hasn't happened to me in a 4WD, I have experienced this in my previous Commodore. It turned out to be the "budget" tyres the previous owners (Randwick City Council) fitted to it. You'd expect the problem to be present at a wider speed range, but it wasn't. Only around 100 km/h. A set Bridgestone RE92s fixed it then.
AnswerID: 3811
Follow Up By: Slunnie - Saturday, May 25, 2002 at 00:00
Thats a good point Savvas. My father has had this with Kuhmo OE car tyres also.
FollowupID: 1623
Reply By: Mick - Saturday, May 25, 2002 at 00:00
Drumming noise you are hearing is coming from the empty space between your ears . All Landrover owners have this space . Drumming is just a beginning of the simptoms , next you will get a bad case of verbal diarrhea . Just take look at the alreadytaken69 . The cure is simple and very effective. Just buy Toyota .
AnswerID: 3812
Follow Up By: Cruiser - Sunday, May 26, 2002 at 00:00
Sarcasm: 100% Spelling, grammar and punctuation: Fail.
FollowupID: 1631
Reply By: Slunnie - Saturday, May 25, 2002 at 00:00
Hmmm, Irony is a funny thing isn't it.
AnswerID: 3818
Reply By: Mike - Monday, May 27, 2002 at 00:00
I just wish these cretons would go back to their channel 1&2 on UHF and leave us in peace. Tom, the drumming could be several things, the tyres would be the first thing to check. Wheel bearings may also although they should be a constant noise/feel. If your Universal joints are OK, then your tail shaft may be out of balance. I had this problem many years ago on a Toyota truck, and a rebalance fixed the problem. Good luck and ignore the idiot element, who seem intent on destoying this forum with childish comments.
Happy trails, Mike.
AnswerID: 3848
Follow Up By: Savvas - Tuesday, May 28, 2002 at 00:00
Mike,
Here,here! Absolutely agree with you on the idiot element.
FollowupID: 1644
Reply By: Damien - Monday, May 27, 2002 at 00:00
Well said Mike, a thoughtful & informative reply - take note Alreadytaken69.
AnswerID: 3849
Reply By: Tom - Monday, May 27, 2002 at 00:00
Thanks for the useful comments guys - I'll follow all the suggestions up methodically. It is a pity the children are allowed to post responses - they mess up a what is a valuable forum.
AnswerID: 3856
Reply By: Member - Bill - Tuesday, May 28, 2002 at 00:00
Tom, the drumming could also be harmonics building up in the door skins, or other panels. I have heard this occurring in a few different brands of vehicle. I believe that it can be solved by spraying the inside of the dor with a bituminous coating, similar to sound deadening. This reduces the vibration. Bill Church
AnswerID: 3873
