Pajero will not disengage 4wd
Submitted: Wednesday, Jul 15, 2015 at 17:08
ThreadID: 119500 Views:3258 Replies:4 FollowUps:8
any one had a problem with the above thanks Ian?
Reply By: Bigfish - Wednesday, Jul 15, 2015 at 17:12
No. I haven't..................
AnswerID: 557049
Follow Up By: Member - Ian F (WA) - Wednesday, Jul 15, 2015 at 17:16
It isn't mine, chap next to me in the CP Denham WA.
FollowupID: 843352
Follow Up By: Member - Ian F (WA) - Wednesday, Jul 15, 2015 at 19:22
apparently the problem is low to high 4wd and it's a 2003 model and he has just changed solenoids etc.
That's a worry with modern 4wds, computer orientated, I own a DMAX.
FollowupID: 843363
Follow Up By: D-MaxerWA - Wednesday, Jul 15, 2015 at 20:47
When I was in Coober Pedy 2 weeks ago, the majority of vehicles in the CP were Dmaxes. Just saying.
D-MaxerWA
FollowupID: 843369
Reply By: Member - Nutta - Wednesday, Jul 15, 2015 at 17:26
I like to engage and disengage with the auto in neutral, sometimes i'll let it roll a little while disengaging, if i dont it tends to stay in low, mines a colorado but i think they all work the same.
Otherwise it could be a crook solenoid, cheers.
AnswerID: 557050
Reply By: Frank P (NSW) - Wednesday, Jul 15, 2015 at 17:27
A few more details might help if there's a tech problem. eg. What year and model.
A transfer case can temporarily become stuck in 4WD if the vehicle has been driven around a tight bend or manoeuvred (like backing a trailer or caravan with lots of steering lock) in 4WD.
If that is the case your CP neighbour needs to drive forward and/or backward and/or alternate between the two to unwind the drive train.
AnswerID: 557051
Follow Up By: Frank P (NSW) - Wednesday, Jul 15, 2015 at 17:28
You beat me to it by seconds, Nutta :-)
FollowupID: 843353
Follow Up By: Frank P (NSW) - Wednesday, Jul 15, 2015 at 18:45
"needs to drive forward and/or backward and/or alternate between the two "
Should have added - in a straight line.
FollowupID: 843357
Reply By: TomH - Wednesday, Jul 15, 2015 at 17:57
Reverse up for a bit and it should come out As said windup causes it.
AnswerID: 557053
Follow Up By: bigden - Wednesday, Jul 15, 2015 at 20:04
Just another voice that says reverse a few metres. The front axle actuator binds on many different brands
Pajero forum has a big write up on it
Some times it will take a few goes
FollowupID: 843364
Follow Up By: member - mazcan - Wednesday, Jul 15, 2015 at 20:13
yes just reverse in straight line sometimes my old mazda does it with the auto hubs especially if i have just driven onto a hard surface and turned before trying to disengage 4wd
FollowupID: 843366
Follow Up By: Member - Chargergirl76 - Thursday, Jul 16, 2015 at 12:50
Our Prado does it on occasions and reversing and then going forward again will generally fix it for us
FollowupID: 843383
