Blocked non return valve on caravan water system
Submitted: Sunday, Jul 19, 2015 at 12:50
Kevin S - Life Member (QLD)
I have just cleaned the non return valve, again, on the external
water supply line on the caravan. The problem manifests itself by
water running back out of the inlet when the pressure pump is operated.
The obstruction was small dark green things that look like small plant leaves. At first I thought ants might be carrying them in from a nearby shrub but the problem has occurred again after I put an insect proof cover over the inlet, when not in use.
So I assume that it is some kind of bacterial growth. Does anyone know what it is and the best treatment to keep it under control? The blockage has occures about three times in a year.
Thanks.
Cheers, Kevin.
Reply By: CSeaJay - Sunday, Jul 19, 2015 at 14:12
Milton, also used as baby bottle cleaner, can be used for bulk tanks.
Boaties often use that for their tanks as
557164
Reply By: Member - reggy 2 (VIC) - Sunday, Jul 19, 2015 at 16:29
do u have a hot
water system in the van if so check out the electric anode they tend to fall to bits I have changed
mine twice in the last eighteen months bits look like green things if it is the problem make sure you give it a good flush out check the filters on the taps in side
cheers hope this helps
557168
Follow Up By: Kevin S - Life Member (QLD) - Sunday, Jul 19, 2015 at 17:36
We had a hot
water unit in a previous van so I am familiar with the martial from the sacrificial anode. But there is not one in this van and the material is quite different in appearance. Thanks for your response.
Kevin
843476
Reply By: Tim F3 - Sunday, Jul 19, 2015 at 19:16
Do you have any clear plastic hoses any where that allow light in and promote alge growth in the
water,its surprising how many manufactures do this.
557171
Follow Up By: Notso - Sunday, Jul 19, 2015 at 19:45
Yes, I had this problem with one of my vans. If so, just slip some of that split black plastic convoluted electrical cable insulation of the correct size over the clear hose.
843484
