G V M upgrade
Submitted: Tuesday, Jul 21, 2015 at 11:03
Member - G G 4 7 W A
Has anyone had a upgrade to a 100 Series ,what has to be done ,with upgrade does will it increase your G L M buy very much.
Reply By: MEMBER - Darian, SA - Tuesday, Jul 21, 2015 at 14:04
Not to devalue advice gained here in anyway.........the specialist site Landcruisers Online is knee deep in owners who have been there and done it all on every cruiser model made. Free to join - just takes a day of two to formalise.
Lcool
557233
Follow Up By: Member - G G 4 7 W A - Wednesday, Jul 22, 2015 at 10:40
Thanks G G
843556
Reply By: TomH - Tuesday, Jul 21, 2015 at 14:41
What do you mean by GLM
Not a normally used term and yes LCOOL has dozens of owners who have done it.
No it doesnt increase your towing limit only the GVM of the tug
557237
Reply By: vk1dx - Tuesday, Jul 21, 2015 at 14:48
We just upgraded to 3700 Kg on a 20074.2td GXL IFS. A 500 Kg gain. Legal at last. We had alreayd done most of the work back in 2010 when we got the car, we had fitted Bilstein shocks, had the torsion bar mount and lower wishbone arms upgraded as
well as one grade rear spring upgrade. Just as a matter of our safety and car capability. So we were really just after the paper work, some more mechanical things as necessary and tests.
We engaged an engineer to oversee and manage the work. We got the engineers name from the RTA site.
We had to fit air bags to the rear to aid stability. Yes they do adjust the height but they are there to aid stability. I don't really want any lift. Drive the car sensibly and you don't need one, even in the high country. The engineer then filled out the reports after a braking and stability test drive on a track that we hired for an 1/2 an hour.
All good and then over the pits. We had to fit a new compliance plate and get new tyres (we knew about the tyres). An hour later, back to the pits for approval and DONE!.
557238
Reply By: member - mazcan - Saturday, Jul 25, 2015 at 14:09
hi G G 47 W A
Westcoast
suspension do G V M upgrades and would be able to give you all the relevant imfo no connection with them just past the info on
557380
