cruise control will not hold 110kph
Submitted: Monday, Apr 12, 2004 at 10:38
ThreadID: 11973 Views:2308 Replies:3 FollowUps:4
Hi Guys i hope everyone had a good and safe Easter,My kids spend Sunday bouncing off the walls.Any way can anyone help me my cruise control it will not hold 110kph,its ok up to 105,Its a AP 60 (I think).Is there an ajustment i can do
regards uppy
Reply By: Dave from Fraser Coast 4WD Club - Monday, Apr 12, 2004 at 11:07
how many magnets are you running and have you cut the black wire??
AnswerID: 53921
Follow Up By: uppy - Monday, Apr 12, 2004 at 12:18
Dave Ive got 2 magnets and the black is not cut as far as i can see
regards uppy
FollowupID: 315597
Reply By: Dave from Fraser Coast 4WD Club - Monday, Apr 12, 2004 at 13:29
In setting mine up it would cut out around 60kms from memory.
Try taking off a magnet!!
I currently run with 1 magnet and the wire cut, and it has held speeds from 50 to 120 (furthest I've tried)
AnswerID: 53928
Follow Up By: cwebb - Monday, Apr 12, 2004 at 19:04
I had exact problem when installing AP60 on my car. If you are lucky, you can probably get away with just cutting the black wire, as it halves the number of cycles the computer is monitoring. Will be a treat after that. It is a good cruise control for the price.
FollowupID: 315609
Follow Up By: uppy - Wednesday, Apr 14, 2004 at 09:57
thanks guys for the replies.I did pull the thing in.So im not sure about this black wire thing.Where is it and where do i cut it etc... Again thanks for the infro
regards uppy
FollowupID: 315792
Follow Up By: joc45 - Wednesday, Apr 14, 2004 at 11:06
If you take off one magnet, replace it with a bit of steel about the same weight to maintain balance of the shaft. I used a bit of flat iron, filed a couple of grooves to take the wire tie, then spread araldite over the wire and magnet/steel. Never comes off again.
Gerry
FollowupID: 315803
Reply By: Member - Jeff M (WA) - Tuesday, Apr 13, 2004 at 16:42
Uppy if you need a hand, we can maybe look at it on the weekend...
AnswerID: 54038
