3.0TDI patrol...resonence at @2400 2600rpm???
Submitted: Saturday, Apr 17, 2004 at 23:39
ThreadID: 12147 Views:2059 Replies:3 FollowUps:1
I get a resonating vibriation at around the 2400-2600rpm mark during normal driving.
Have a Safari snorkel fitted and am pretty sure the noise is developing somewhere via the intake near the airfilter???
Any one with similar issue and or remedy???
Reply By: Member - Rick - Sunday, Apr 18, 2004 at 01:49
its normal andrew, mine does the same thing.
rick.
AnswerID: 54774
Follow Up By: Member -Bob & Lex (Sydney) - Sunday, Apr 18, 2004 at 16:46
I have it to but don't hear it often now as I have got used to it.
FollowupID: 316516
Reply By: Peter 2 - Sunday, Apr 18, 2004 at 07:28
Do Nissan's have a plastic box hanging off the side of the air intake like other vehicles, lot's of Toyota's do. It's there to remove (mostly) the sort of problem you are having.
Often fitting a snorkle or changing filter elements to a non standard variety can affect the resonant point of the air intake.
Of course fitting a snorkle if it's on the drivers side moves the air intake closer to the drivers ear too, which can mean you here/feel things more.
AnswerID: 54779
Reply By: Magic - Sunday, Apr 18, 2004 at 08:26
After Nissan fitted snorkel to my navara I have the same problem when I checked the connection between snorkel and the filter I found the bustards put only two bolts instead of seven and cyclonic box b4 air filter was hanging on one screw instead of 3 to check if they did good job you have to remove all plastics covers in front quarter panel above the wheel good luck.
AnswerID: 54780
