troopy fuel filter part
Submitted: Tuesday, Apr 27, 2004 at 14:41
ThreadID: 12418 Views:1961 Replies:5 FollowUps:5
I bought a secondary fuel filter for the troopy and in the kit was a small rubber o ring about 4 or 5 mm diameter . where does this o ring go . refer to diagram.
[ View Image]
Reply By: Member - glenno (QLD) - Tuesday, Apr 27, 2004 at 14:48
please disregard the view image link
AnswerID: 56204
Reply By: Bob Y. - Qld - Tuesday, Apr 27, 2004 at 15:03
glenno,
Think that little o-ring is a throw back to earlier models that had a bleed screw on top of the filter case. Same filter is/was even used in toyota trucks.
I might be being pedantic, but I call that one the primary filter, because it filters the fuel first.
Hooroo...
AnswerID: 56207
Follow Up By: Member - glenno (QLD) - Tuesday, Apr 27, 2004 at 15:09
Thanks bob . I mean the element replaceable one that is closest to the air filter . Not the one with the little pump on top . Am i confusing myself .
FollowupID: 317989
Follow Up By: Member - glenno (QLD) - Tuesday, Apr 27, 2004 at 15:51
Managed to change both filters ok . took about an hour .
FollowupID: 318001
Reply By: Member - JEFF - Wednesday, Apr 28, 2004 at 07:25
G'day Glenno
Mate I purchased a troopy back in sept last year It also has a second fuel filter. Tell me, is the 1st filter (not the one with the pump on top) the same type as the other one, or are they different to each other??
regards jeff
AnswerID: 56328
Follow Up By: Member - glenno (QLD) - Wednesday, Apr 28, 2004 at 09:44
Jeff its a replacement cartridge type . cost me $7 . I found the easiest way to replace it is to undo the two bolts on top then tip it upside down ,then you can get at the bolt on the bottom of the unit(14mm ring spanner). also easier to replace the large rubber washer that sits under the top of unit.
FollowupID: 318076
Reply By: Member - JEFF - Thursday, Apr 29, 2004 at 09:07
thanks Glenno for the info Tell me, is the whole unit a toyota unit??
regards jeff
PS SORRY FOR THE LATE THANKYOU
AnswerID: 56529
Follow Up By: Member - glenno (QLD) - Thursday, Apr 29, 2004 at 09:48
Jeff toyotas price is (primary fuel filter)$21.75
donaldson brand $5.86
jeff toyotas price is(secondary fuel filter)$52.00
donaldson brand $15.27
FollowupID: 318276
Reply By: Member - glenno (QLD) - Thursday, Apr 29, 2004 at 09:52
Jeff I bought,
1 air filter.
1 primary fuel filter.
1 secondary fuel filter.
1 oil filter.
1 air filter.
10 lts of gtx diesel oil.
cost me $97.92
AnswerID: 56533
Follow Up By: Member - glenno (QLD) - Thursday, Apr 29, 2004 at 09:54
Sorry 1 air filter only
FollowupID: 318278
