Toyota Prado Stereo
Submitted: Tuesday, May 04, 2004 at 15:45
Tim
Hi guys, just in the process of trading in the Jack for a 01 prado RV. I am considering keeping the good stereo I have put in the jack and slotting it in the new prado however when test driving the prado I remeber looking at the stereo and thinking it was an odd size.
Can someone measure the length and height of the am/fm tape deck in the prados and let me know PLS.
Tim
Reply By: Member - Jeff M (WA) - Tuesday, May 04, 2004 at 18:10
If it's anything like the GU's it'll be a double DIN size. No worries, just gives you a good place to put the UHF! ;-)
Double check with others, but I would imagine that's what it is.
You can get DIN surrounds from prestige communications to suit most GME radios. Will make for a nice neat finish.
57206
Reply By: Phil G - Tuesday, May 04, 2004 at 23:09
Tim,
Its a standard DIN size with a DIN sized pocket below. On the RV I had, I fitted a DIN sized radio/CD with a Uniden UH088
UHF radio underneath. You'll need to mess a bit with the OE brackets for a perfect fit.
57257
Follow Up By: Tim - Wednesday, May 05, 2004 at 01:32
Thanks guys, will change it tomoroow, UHF won't fit though, I have a detachable face uniden so I will just get one of those blank cover things.
Tim
319006
Follow Up By: Phil G - Wednesday, May 05, 2004 at 19:55
Tim,
you can also leave the pocket in there and mount the new stereo above it.
319085
