fuel gauge tank sencor
Submitted: Friday, May 07, 2004 at 04:15
ThreadID: 12667 Views:1799 Replies:2 FollowUps:2
Hi has any one had trouble with and 80series fuel tank sender. Mind indicates full at all times, only started doing it 3weeks ago. Also whats the easiest way to get it out. do i have to remove tank from 4by to get at it.Any help would be gr8 as i am going away in 4weeks and i need it fixed.
Thanxs
Reply By: Steve L - Friday, May 07, 2004 at 07:45
Depends which tank it is.
If it's the sub tank it's easy to get to - simply lift up the carpet and lining in the cargo area, and it all sits under a plug in the floor (basically the connection is from the top of the tank).
If it's the main tank, you may have to pull the tank out, though I have no experience with the main one (I know about the sub tank as we found all this out when putting the LR tank in).
AnswerID: 57580
Follow Up By: Member - Munny @Mt Gambier SA - Saturday, May 08, 2004 at 00:27
Thanxs steve
Its the main tank and if im out in the rough stuff it will work 4 a little while then go back 2 reading full
FollowupID: 319456
Reply By: Wayne (NSW) - Sunday, May 09, 2004 at 16:49
Munny,
Had the same problem. The sender unit got stuck when one of the baffles moved and held the float in the full postion. I got into the tank via the inspection plate in the back seat area. Lift the carpet and you shouild find it.
I hope I am not to late with the info but I have been away all weekend.
Wayne
AnswerID: 57853
Follow Up By: Member - Munny @Mt Gambier SA - Tuesday, May 11, 2004 at 18:01
Thanxs wayne i have been putting this task off , now i will have ago at it as i throught some one wood have and idea for me .
Thanxs again
FollowupID: 319909
