GU Patrol + ARB bar + 10,000lb winch
Submitted: Monday, May 10, 2004 at 08:37
ThreadID: 12738 Views:2545 Replies:3 FollowUps:1
Hi all,
Can you install a 10,000lb Warn winch in an ARB bar after it has been fitted to a GU Patrol? I know you can get a 9000lb in and out but the 10,000 is a big beast!!
Leroy
Reply By: Kiwi Ray - Monday, May 10, 2004 at 10:35
Hi Leroy
AnswerID: 57949
Reply By: Kiwi Ray - Monday, May 10, 2004 at 10:38
Hi Leroy
I will start again
I have a 10,000 lb in a ARB bar with no problems.
My bar is a steel one fitted to an 80#
Youmay need to check other ARB models
Ray
AnswerID: 57950
Reply By: Happy GU Owner - Monday, May 10, 2004 at 17:43
Leroy,
I have GOOD NEWS for you!!
I have a GU Patrol with a Warn 10,000 lb winch on a ARB Deluxe Winchbar and yes I have taken out the winch and re-installed it without removing the bar from the vehicle. It is not easy as I did it by myself and they are verrrry heavy, no friends to help at the time! Would be much easier with two.
Obviously you need to remove the bottom air deflector/bash plate for this, lift winch onto a milk crate or similar which will fit under the front of your vehicle, and then pull the winch up into position through the cable inspection hole in the top of the bar. You need to lift one end of the winch up higher than one of the chassis rails and slide it up over the rail before you can lift the other end of the winch into the bar frame. From there you can slide it into the correct mounting position and let it rest on the bar whilst you take a rest or find the mounting bolts.
Best of luck with it.
AnswerID: 58012
Follow Up By: Leroy - Monday, May 10, 2004 at 21:08
Fantastic! Thanks for that you've made my night!
Leroy
FollowupID: 319810
