Locking nuts for driving lights?
Submitted: Monday, May 10, 2004 at 23:31
ThreadID: 12770 Views:8357 Replies:5 FollowUps:1
Howdy all, hows the battle?
just chasing some info on some locking nuts that can be used for anti-theft for driving lights. I've heard that there are nuts that can be locked by a key (?), so no 5 finger cretans can swipe our luminious accessories. This also allows easy removal aswell ( instead of welding a nick etc. ). Is this the case & does anyone know where 2 get them?
cheers in advance
rowen
Reply By: Member - Captain (WA) - Monday, May 10, 2004 at 23:53
Hi Rowen,
I had a set of locknuts that needed a special socket to remove it. The nut was like dome shaped with pins holes where the matching socket would fit in. They work fine IF the spotlight hole is recessed a bit. By that I mean if a set of pliars can get a good grip on the nut then you can undo it easy enough. But if you have to reach up to get to the nut (ie. need a small extension bar on the socket) then they work very well.
I have had mine for many years though, bought them from Marlows (now Supercheap auto parts), not sure if they still stock them. But would have thought that ARB or OppositeLock, TJM etc... would all stock them (but porbably wrong!!!)
Captain
AnswerID: 58103
Follow Up By: madcow - Tuesday, May 11, 2004 at 07:54
I am pretty sure they are called "Barri" nuts.
FollowupID: 319854
Reply By: John - Tuesday, May 11, 2004 at 00:47
ARB sell them, check the web site.
AnswerID: 58107
Reply By: desray - Tuesday, May 11, 2004 at 00:56
Hi Rowan I have spotlights on my car. I drilled a hole through the bolt just below the nut and put a small padlock on. Dont loose the keys though Ray
AnswerID: 58108
Reply By: Member - Bradley- Tuesday, May 11, 2004 at 12:32
I found Coventry Fasteners stock a range of security fasteners from 'Endeavour' they have all sorts of tamper proof bolts / nuts and screws. The best ones i found for driving lights were a cone shaped blank that fits over your existing bolt or nut. and leaves a smooth tapered surface that you can't get on to with vice grips etc. All you do is adjust your lights, do up all the bolts nice and tight, and drive these over the bolt heads etc. Yeah you need a cold chishel or similar to get em off at home . BUT so does any scumbag !! The problem with most of the pin drive nuts etc. is that you are limited in the torque you can apply to the fixture..
AnswerID: 58142
Reply By: Mark- Tuesday, May 11, 2004 at 21:51
With my lightforce 170's, I put longer bolts in then tack welded an extra nut on the end of the bolt. This allows me to still adjust the lights using the inner nut. So far so good.
AnswerID: 58239
