Ox winch in ARB bar GU Patrol series 3
Submitted: Tuesday, May 11, 2004 at 23:12
Gerk
Tried this earlier, Does anyone know if an Ox hydrolic winch will fit an ARB bar on a GU Patrol series 111 ST?
Reply By: Truckster (Vic) - Wednesday, May 12, 2004 at 01:16
Should fit an ARB bar, but std bar it probably wont.
Call TJM dealer they will tell you straight away
58261
Reply By: brian - Wednesday, May 12, 2004 at 08:45
Yes it fits i have exactly that combo on my 2002 patrol
58277
Follow Up By: Gerk - Wednesday, May 12, 2004 at 10:21
Many thanks again guys, Brian do you have the dtronics and the unifilter on your patrol?
319991
Follow Up By: Member - AndrewPatrol - Friday, May 14, 2004 at 19:47
Brian,
With the hydraulic winch, is it really slow or can you put put with it and under no-load conditions I've heard that they are a bit quicker. I realise that if you're stuck what the diff if it takes all day, what're gonna do otherwise (beats a hand winch). I'm not really after a comparison with the electric ones just whether or not they're worth it?
Andrew
320369
Reply By: brian - Wednesday, May 12, 2004 at 13:46
do not have ditronics as truck is still under warrenty,just, 90000k.have run finer filter but changed back to origional so that i dont have any warrenty hassels.
I am advised that even when you disconnect ditronic nissan can determine it was fitted,didnt want it to be a factor if i made a claim thats all.
with the air filter no noticeable difference except oil filled easy to clean every few days in dusty areas,i just like them.
58315
Follow Up By: Member -Bob & Lex (Sydney) - Wednesday, May 12, 2004 at 16:24
You got the 3.0ltr or 4.2 as they don't recomend them on the 3.0 as they reduse the air flow & can cause problems with the air flow meter.
320031
Reply By: brian - Friday, May 14, 2004 at 21:01
Hello yes the ox is slower to retrieve but it pulls like nothing else,my mates warn 8000lb wont pull his patrol on flat grass at my house with brakes on the ox will drag my patrol across concrete. i have 3litre.
58652
