3 way fridge
Submitted: Saturday, Aug 01, 2015 at 17:21
ThreadID: 129624 Views:2537 Replies:2 FollowUps:0
Hi having problem with 3 way giving off a smell when you pull up after travelling, works ok on gas or 240v while stationary but when you move on and stop, the inside of the van has a strong odour, once aired out and running on gas or 240 no smell have had the evaporator part of fridge replaced 4 months ago. they say nothing wrong with it, does any one have a different answer
Reply By: Member - Michael P (QLD) - Saturday, Aug 01, 2015 at 19:55
Normally the gas on those is a mixture of Ammonia & water, If the smell is like ammonia would suggest a leak, possibly from earlier repairs.
Regards Mike.
AnswerID: 588208
Reply By: Phil 23 - Sunday, Aug 02, 2015 at 06:05
First thought that comes to mind is something overheating in the 12v wiring.
Even if the cable is heavy enough, a bad connection can cause excessive heat.
AnswerID: 588215
