2011 holden colorado lxr brake rotor replacement?
Submitted: Sunday, Aug 02, 2015 at 16:39
ThreadID: 129631 Views:5832 Replies:2 FollowUps:1
anyone know how to remove the old rotor and put the new one on. It tried and got down to the hub and couldnt get the damn thing off lol. Its a 4x4 holden colorado rc dual cab with a steel tray on the back.
Got the 280mm rotors too i know that for sure just having trouble getting the old one off haha
Reply By: brianH - Sunday, Aug 02, 2015 at 19:55
Hi Brendan L5 i am no expert but I think you can hire hub pullers from bunnings that would do the job.Then you would need to check, clean and pack the bearings, replace the seal and adjust. I think it you do not have a great deal of mechanical it might be better to take the vehicle to a mechanic.cheers, Brian
AnswerID: 588229
Follow Up By: Brendan L5 - Monday, Aug 03, 2015 at 08:55
Thanks for that. I took your advice and just dropped it in to my local racq approved mechanic :p
FollowupID: 856297
Reply By: Ross M - Tuesday, Aug 04, 2015 at 15:07
Remove the caliper, undo wheel bearing adjuster, remove hub and disc, then hold disc and loosen the 6 bolts holding the dicc to the inside face of the hub.
Remove old disc, fit new disc and reverse assemble.
AnswerID: 588843
