Eotrackme how to change devices
Submitted: Thursday, Aug 06, 2015 at 17:57
ThreadID: 129888 Views:2274 Replies:1 FollowUps:1
HELP.
I'm new to Eotrackme me, I've got it working fine . But would like to change from my spot to my iPhone . Can't find the info , can someone point me in the right direction? Great system tho.
Robbo
Reply By: ExplorOz - David & Michelle - Friday, Aug 07, 2015 at 10:23
Robbo,
You are not so much changing devices, you are just simply adding another. There is no reason to delete or remove your spot device unless you are no longer using it but make sure you save the data first.
To add the iPhone follow the Documentation on the EOTrackMe page that talks about "Settings for uTrackMe Beacon 2 (iPhone & iPad)" install the apps and setup as documented and you should be away.
David
AnswerID: 588958
Follow Up By: Member - shane r1 - Wednesday, Aug 12, 2015 at 06:59
Thanks I will have another go, away from home at the moment, so will leave it till this trip is finished.
FollowupID: 856973
