Thursday, May 20, 2004 at 18:03
You always take your chances with trailers that are not setup specifically for off road. The corrugations are the only thing that is likely to do the damage and this is only because there are so many of them. A lot depends on when the tracks are graded. If you are going the route you mentioned and not going to Broom I would not bother going to
Derby. Just cut up to
tunnel creek from
Fitzroy crossing. You will be saving yourself 200km of nothing. Anyway, the first 130 Km of the GRR from the western end (
Derby) there is absolutly nothing to see.
If your trailer survives the tanami then you should have no problems on the GRR.
On the tanami the corrugations will be worse between the WA border and
Halls Creek otherwise track is good as it is generally maintianed for the
mine. On the GRR the western section of the GRR is smooth sailing.The worse corrugations will be the eastern section between the Kalumbaru Rd and Ema Gorge. If you are lucky you will follow the grader. As the finch is a shorter van you should have no problems but just drive to the conditions and remember you have the van on the back which is stappled together not glued and screwed. The kalumbaru road can also get very corrugated depends when it was last graded. So you ewill need to decided whether it it is worth going up to the Mitvhel falls. Tey and find out if any
water is flowing over the falls if not it is not worth the trip up there. However if you do go to the
Mitchell Falls I would leave your van at the
camp site no 2 at
King Edward river and then go into Mitchel Falls from there (70Km). We did the return trip in a day. When at the falls we chose to Fly into the falls and walked out. This way we could take our time. You have plenty of time in 6 Weeks. We did the same trip but included
Broome and Cape Laveque ( one of the nicest
places in Austaralia) in the six weeks from
Melbourne but did not do anything around Alice. .
We always stay at the caravan
park on
the lake in
Kununurra. It is just out of town but really nice.
There is also a nice caravan
park in
Katherine that is half way out to
the gorge. It has big shady trees, a good pool and and does not get a busy as the ones in town.
You always take your chances with trailers that are not setup specifically for off road. The corrugation are the only thing that is likely to do the damage and this is only because there are so many of them.
Only my opinions but may be helpful.
59440
