Camper van fridge
Submitted: Friday, Aug 21, 2015 at 10:07
Member - Crocles
Hi all,
I have a Jayco Dove OB with a 90lt 3-way fridge. Based on info from this site I fitted a small fan to the upper external vent which helped the efficiency of the fridge quite a lot. I fitted it with a manual switch but would like to add a thermostat.
My question is what temp thermostat would be best suited to this set up?
Thanks in advance for any info
Croc
Reply By: Notso - Friday, Aug 21, 2015 at 10:15
Never done it myself, always use a switch. A friend in the Van Club did and used a 50 degree thermostat.
589487
Follow Up By: Member - Crocles - Friday, Aug 21, 2015 at 20:53
Thanks Notso. 50 rings a bell for some reason.
857411
Reply By: HKB Electronics - Friday, Aug 21, 2015 at 12:10
Basically it needs to be slightly higher than the expected max ambient temperature
your likely to encounter, ie if you intend to travel north in summer then 25C wouldn't be
any good as the fan would be running most of the time, 40 would probably be ok as the fridge would most likely be running continuously at that ambient any being a 3 way type. Another method you could use to determine the required range would be to turn the fridge on after it has been off for a few days let it run for an hour or so then measure the temperature near were the pipes leave the heater and use that as a guide to the temperature required.
589494
Follow Up By: Member - Crocles - Friday, Aug 21, 2015 at 20:54
Thanks mate. Good advice!
857412
Follow Up By: Member - bbuzz (NSW) - Sunday, Aug 23, 2015 at 09:42
If you can get the following to load it has all the info you need.
Fridge Fans
bill
857455
Follow Up By: Member - Crocles - Sunday, Aug 23, 2015 at 19:50
Thanks Bill,
Some very useful info there. My fan is set up already as shown and will add thermostat.
857471
