camper trailer bushes
Submitted: Thursday, Sep 10, 2015 at 18:46
twitchdup
G'day
Iv got a 2006 johnnos deluxe camper trailer that iv just bought from my father in law, im desperetly trying to find new
suspension bushes, if anyone knows the size/measurements or any info that would be great.
Troy
Reply By: Notso - Thursday, Sep 10, 2015 at 18:52
Talk to the manufacturer.
Johnn'os
Or pull out the pins and measure it.
590226
Follow Up By: twitchdup - Thursday, Sep 10, 2015 at 19:00
Iv sent them an email and as this is my first camper, to remove the pins do I jack the actual trailer up not the leafs? then undo
the nut and the leafs will come away from the frame?
858232
Follow Up By: Notso - Friday, Sep 11, 2015 at 15:37
Generally right, but if I was you I'd take it to a mechanic or
suspension shop and let them do it.
858246
Reply By: Member - Tony F8 - Sunday, Sep 13, 2015 at 06:34
Imho, I would do the bushes yourself, as
well as the the wheel bearings. This knowledge will be invaluable down the track.
590294
Follow Up By: twitchdup - Sunday, Sep 13, 2015 at 20:11
Yeah matw did all bushes and wheel bearings myself over the weekend, now I gotta figure out the go with the dual batteries, apparently there wired up wrong, positive to negative, then positive and negative running up the front to anderson plug.
858329
Follow Up By: Member - Ed C (QLD) - Sunday, Sep 13, 2015 at 23:33
I'm thinking the batteries are not "wired up wrong" at all..
The 'in series' connection that you have described suggests to me that the batteries are in fact 6Volt (x2), connected in series to supply 12Volts (nominal).. A not uncommon practice, I believe...
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
858338
