Wednesday, Sep 16, 2015 at 22:17
JB
I have a 2013 200 series LC. I tow a 3400kg Van. The tow ball weight is 340kg.
I previously had a 2009 200 series and quickly found that with the bull bar, drawers, waeco, tools, full
fuel tank plus passengers and importantly when another 340kg [tow ball weight] was applied, that I was almost illegal and on cusp of exceeding the GVM of 3350kg. To acheive a safer towing situation I found that I needed to both raise the rear end [that went down when van attached], but critically to ensure that the weight removed from front
wheels was transferred/redistributed back by way of a Weight Distibution Hitch.
I installed Lovells all round [front and rear] I also fitted Air Bags. I acheived a reasonable towing set up over tens of thousands of k's towing the Van.
When I purchased 2013 LC 200 I decided to get the GVM upgrade from new which gave me a second compliance plate that states new GVM 3850kg. I did not fit Air Bags as I could see no benefit for my rig - it is level, most of lost weight transferred back to front
wheels [some also to Van
wheels] and after 40,000k,s of vanning I feel that the set up is not just legal, but as safe reasonably as I can make it. I also used Lovells on this vehicle.
Whilst jacking up the rear end may make the vehicle level, the steering and dynamics of the vehicle will be compromised, unless you redistribute the weight using a WDHitch.
Some of the best advice you will find on safe towing is that by Collyn Rivers - search Vehicle Dynamics. You will likely find advice that says if rear
suspension upgraded, then the front must also be upgraded lest you lose steering and handling capability.
I would establish the weight of the laden van as
well as the tow ball mass/weight and talk with expert WDH fitters, I am not suggesting that you need a GVM upgrade, however you may, dependent upon weights involved.''
WDH are a pain and create work, however I am influenced they do increase vehicle safety - [assuming you dont have a small Van].
Good luck.
590432
