Ford Ranger Ute Lining
Submitted: Friday, Oct 02, 2015 at 14:23
ThreadID: 130482 Views:2664 Replies:4 FollowUps:2
What's the best product to put on the steel tray back under an aluminium checker plated canopy? Thanks.
Reply By: Les - PK Ranger - Friday, Oct 02, 2015 at 14:40
Grant, you mean a covering to protect the steel tray ? (Not insulation under the canopy.)
Have you seen the Rhino coating ? Very tough.
Other than that, would suggest marine type carpet, spray glue adhesive.
AnswerID: 591035
Follow Up By: Flighty ( WA ) - Friday, Oct 02, 2015 at 14:59
Les
Rhino coating is a good product yes, but not sure that marine carpet is a good idea though, think maybe any water and moisture that does manage to get between canopy and floor may cause rust issues.
Depending of course if canopy has its own floor or not.
Flighty
FollowupID: 859088
Follow Up By: Les - PK Ranger - Friday, Oct 02, 2015 at 15:28
. . . or ribs in the floor for water to drain away . . .
FollowupID: 859093
Reply By: Member -Pinko (NSW) - Friday, Oct 02, 2015 at 14:53
Also look at 'Raptor' by Upol.
Comes in a choice of colours
AnswerID: 591039
Reply By: Phillipn - Saturday, Oct 03, 2015 at 09:55
I have Rhino coating in the tub of my BT 50 It prevents moisture and rust, it`s non slip and easy to clean. 4 mm thick on the floor and tail gate, 2 to 3 mm on the sides.
AnswerID: 591103
Reply By: Member - silkwood - Monday, Oct 05, 2015 at 15:00
Line with cartons of Coopers Pale Ale. Replenish as required.
Mark
AnswerID: 591208
