Air conditioner
Submitted: Friday, Oct 02, 2015 at 20:07
Jerry D
Hello Group...
Iam trying to find out if I could run air conditioner like the one of the portables from Kogan or window type from portable generator?
If yes, what wattage I will need?
Kind regards
Jerry
Reply By: Member - Bigred13 - Friday, Oct 02, 2015 at 20:13
Hi Jerry ,yes they will be ok ,just make sure that you have a large enough one to handle all your requirements ,plus a bit .The inverter generators are the best as most modern equipment require pure sine wave power .
591069
Reply By: HKB Electronics - Friday, Oct 02, 2015 at 20:17
The problem with aircons is the surge current to get them started could be two, three or
more times greater then the run current. I would suggest a soft start aircon unit, you'll need to look
at the specs of the airconditioner to work out what size genset you require.
591070
Reply By: Member - Bigred13 - Friday, Oct 02, 2015 at 21:01
Hi Jerry if you look on the specs for that unit it is 950W electrical input ,but because that unit it only evaporative ,a 1kva would probably be ok ,as it is only a fan and pump ,but if you need any other power needs go bigger
591078
Reply By: Member No 1 - Saturday, Oct 03, 2015 at 10:01
We need to know the input watts of the A/C...else refrigeration watts may suffice
591104
