Gaskets, to smear with oil or sealant
Submitted: Monday, Oct 12, 2015 at 10:42
ThreadID: 130571 Views:2589 Replies:5 FollowUps:4
hi all, we are replacing the rear timimg case seal on a hj60 2H and i am just a wonder if i should use a smear of oil or gasket-goo on the gaskets??
Reply By: Lex M - Monday, Oct 12, 2015 at 10:50
I'd use this.
Permatex no 3
AnswerID: 591487
Follow Up By: LandCoaster - Monday, Oct 12, 2015 at 11:01
thanks for the post Lex... do you still use the paper gasket when using the permatex?
FollowupID: 859530
Follow Up By: Ron N - Monday, Oct 12, 2015 at 11:05
Lex has the best suggestion. Silicone sealants are not desirable on engine gaskets because they can produce lumps of surplus silicone when the parts are tightened up. These lumps of silicone can then fall off and end up in the lube system of the engine, blocking oil pump suction screens, and other small oil passageways, if they get through the pump.
A non-hardening gasket cement such as Permatex No 3 is a good gasket sealant because it doesn't produce undesirable additions to the lube system, it resists high temperatures, and it stays as flexible as silicone.
Make sure gasket sealing surfaces are clean (scrubbed with a non-metallic scourer - not an abrasive cloth), and wipe them down with a suitable cleaning solvent to remove any oiliness before spreading the gasket cement on.
Cheers, Ron.
FollowupID: 859531
Follow Up By: swampy - Monday, Oct 12, 2015 at 12:44
HI ,
A suggestion ,if u have any bolts that go into the water jacket [wet hole ] use Holden head stud sealer . {stops water coming up the bolt and protects it from corrosion ]
swampy
FollowupID: 859537
Reply By: Member - mechpete - Monday, Oct 12, 2015 at 12:31
permatex no 3 ,have used it for many yrs ,it is resisten to fuel an oil ,doesn,t go hard .
cheers mechpete
AnswerID: 591490
Reply By: LandCoaster - Monday, Oct 12, 2015 at 13:21
thank-you for your replies, i will get some today....
please excuse my ignorance, do i use the goo and paper gasket together or just the goo
AnswerID: 591493
Follow Up By: Ron N - Monday, Oct 12, 2015 at 13:40
Use goo and paper gasket together, the Permatex No 3 is not for gasket-less sealing.
FollowupID: 859542
Reply By: snow - Monday, Oct 12, 2015 at 20:26
Have also used grease on paper gaskets
AnswerID: 591516
Reply By: LandCoaster - Tuesday, Oct 13, 2015 at 01:27
thanks for your replies,
ended up using Loctite Aviation Gasket Sealant, repco didnt have permatex and says it is evivilant.... smells great....
AnswerID: 591524
