Gas bottle help
Submitted: Sunday, Oct 25, 2015 at 16:34
Member - Odog
Hi all,
Planning a trip, wife and I, and have purchased a two burner gas
cook top, which also has a grill.. Trip will be about 3 weeks
camping. My question is, on the cooker it says it uses 19mj an hour.. I presume this would be all burners flat out on high..If we boil the Billy's twice a day, and
cook a feed at night, would a 4kg bottle last the trip? Was thinking of taking a 9kg bottle, but if I can get away with a 4kg, would be lighter load on the roof, easier to lift up and down.. Any body able to do the maths, or advise? Thanks.. Odog n Sue
| Some people want it to happen, some people wish it could happen, others make it happen! Lifetime Member My Profile Send Message |
Reply By: Rangiephil - Sunday, Oct 25, 2015 at 16:53
A 4kg cylinder lasts me for 6 weeks at least with a 2 burner gas stove without grill .
Burners are probably bigger than yours as they are regulated cast iron barbeque type circular burners about 13MM in diameter.
Regards Philip A
591957
Reply By: Hoyks - Sunday, Oct 25, 2015 at 17:14
Take the 4kg. It will last a fair while and on a 3 week trip I'm sure there will be more than 1 occasion where you have to drop into town and resupply, just get it filled then if required.
There is no need to haul more gear than you need 'just in case'.
591958
Follow Up By: Hoyks - Sunday, Oct 25, 2015 at 17:27
I've just been playing with some numbers:
At home we go through a 40kg cylinder every 3 months. That runs a 4 burner stove, BBQ and instant gas hot
water for 4 people and warm washers for our clothes.
So running all that gear in a 3 week period our place would use 9kg of gas, so 2 people living off a 2 burner stove, you should have gas to spare by the time you come home.
860040
Reply By: Member - Tony F8 - Sunday, Oct 25, 2015 at 18:55
Okay, 1kg of gas equals 49Mj, so if you have 4kg, you have 196Mj available, if your stove uses 19Mj per hour you have 10.5 hours of stove use if using all the burners, It is now up to you to work out how long it takes you to
cook your meals.
591962
Follow Up By: Member - Odog - Sunday, Oct 25, 2015 at 20:26
Thanks Tony.. That gives me what I need.. Cheers for that.. Odog
860047
Reply By: LandCoaster - Monday, Oct 26, 2015 at 10:32
be carful using the grill, they really chew the gas. 4kg didnt last me, a single camper with toast and veggie everymorning
591975
Follow Up By: Nomadic Navara - Monday, Oct 26, 2015 at 12:24
How long didn't it last?
860060
Follow Up By: Member - Odog - Monday, Oct 26, 2015 at 16:14
I've heard you can boil the billy above the grill, while toasting your bread.. How many days did you get out of it?
860070
Follow Up By: LandCoaster - Wednesday, Oct 28, 2015 at 00:05
i used to get 3-4weeks out of a 4kg without using the grill.
Before getting a second 4kg bottle, i did the oppositre as Odog, I used to lean the bread up against the kettle dropping it onto the element after the kettle had boiled.
After enjoying toast agin with the second bottle i felt paying swap&go fee in remote locations, just about every fortnight rather than paying a hardware half the amount every other fornight (thus 75% cheaper), was more bothersome than leaning my toast against the kettle, so i went back to leaning my toast against the kettle...
until
With the savings I bought a canister stove and a element stove-top toaste maker, then ditched the second lpg bottle...
My last vehicle I had no installed gas, just the portable stove and a proper place for it...
It's more expensive but the convience, versatility and compactness it very very good...
My next vehicle I hope to have a diesel stove..... Gas scares me...
860128
Reply By: Injected - Friday, Oct 30, 2015 at 22:50
My stove is 15 Mj. With cooking toast everymorning and boiling the billy, boss cooking on it every night we get 6-7 weeks out of 4.5 kg bottle.
592165
Follow Up By: Member - Odog - Saturday, Oct 31, 2015 at 09:29
Thanks, that's great to know, I'm keen on only carrying the 4.5kg bottle.. So think that will be good enough to last the trip.. Cheers for that.. Odog
860291
