Hj60 2H Injector Pump and Rockers question
Submitted: Monday, Nov 09, 2015 at 14:49
ThreadID: 130839 Views:1978 Replies:0 FollowUps:0
Hi All,
We have a standard 2H Injector Pump...Under the Deliverly Valve Holder in our IP is a small spring, but in the manual it pictures the small spring in the Turbo DVH's, the non-turbo has a large spring siting outside the valve that doesnt fall out when the cap is removed... has anyone seen this before? can anyone please account for this? Should we have the seals picture in the turbo setup as well..
The feeler guage 'drag' alters when setting the gaps. We replaced the rockers but it is still tricky, it like there is a 'peak' on the top of the valve stems. Should we have repaced the retainer collars on the valve springs? Do the collars wear making peaks? Does the top of the valve stem wear to give an uneven contact between the rocker face which would affect the gap set when valve is closed and valve is lifted?
thank-you for reading my questions and any clarity on these would be really appreciated.
