Re - Kaymar Rear Light
Submitted: Sunday, May 23, 2004 at 00:17
ThreadID: 13087 Views:2993 Replies:7 FollowUps:13
Here's a dumb question that I am sure has an intelligent answer.
I have been kindly given by a fellow forumite a Kaymar rear light to fit to my Kaymar twin rear wheel carrier.
I can fit it to the left tyre holder or the right one both have the mounts avaliable.
Any ideas which one would be better ? and for what reason.
I have scratched my head about this and can't work out which side is better.
Would appreciate your comments.
Reply By: Member - Captain (WA) - Sunday, May 23, 2004 at 02:08
Hi John,
Not sure what vehicle its fitted to, but if barn doors (Nissan, standard toyotas etc...) fit it to the larger door as that way you can still get into the back of your vehicle without turning the light away from pointing behind the car.
When i open my large door, the light is restricted to basically the drivers side of the car with little light directly behind.
However, if on a horizontal tail gate, may be better on passengers side as you can then direct light on what is typically the verge side of the road when stopped.
Captain
AnswerID: 59746
Follow Up By: John - Sunday, May 23, 2004 at 02:20
Hi Captain
Thanks for the reply.
It's a Troopy, so barn doors, good point about the larger door, it is used less than the smaller so as you say would retain some light in the area directly behind the vehicle, great point thanks.
FollowupID: 321346
Reply By: Member Eric - Sunday, May 23, 2004 at 09:04
Fit it to the side were you can get power to it easy'st lol .
Also stick it in both sides , and look out your rear view , see which side dosnt bother you the most .
AnswerID: 59758
Reply By: TravellingVegemite - Sunday, May 23, 2004 at 09:46
I have mine on the LHS as I use it to light the side more than the rear. When I pull off the side of the road to camp, then I put the tent so the car is between it and the road. Therefore I want to light the LHS of the vehicle (by swinging the wheel carrier to the left). Also caravan doors are that side if towing one of them. That's the side you use the most - as opposed to lighting the road!
Roger
AnswerID: 59765
Reply By: Willem - Sunday, May 23, 2004 at 11:47
Seeing as you have twin spares on the Troopie why not buy another Kaymar light and fit it as well. Then you won't have this vexing question to consider!!! Mmmmmmmm......... maybe you should fit a second winch as well and another two spotties and twin laptops and..................hahahahaha
Kindest regards
AnswerID: 59776
Follow Up By: John - Sunday, May 23, 2004 at 14:33
Hi Willem
Thanks for that comment, It's a real good idea as I don't have enough crap to carry now and one more of everything would be just dandy.
This light was given to me by a very kind gentleman ( I know others on here have said different of him) I might be pushing my luck to ask if he happens to have another spare light in his garage. LOL.
Also the other problem besides weight and space with your suggestion is the simple fact that my ship has not come in yet, so cost is always an issue. Poor bloke that I am.
Take care.
Kind Regards
FollowupID: 321378
Follow Up By: John - Sunday, May 23, 2004 at 15:08
Sorry Willem forgot to add that I noticed you still have not added your electric toothbrush to your vehicle's equipment list.
FollowupID: 321380
Follow Up By: Member Eric - Sunday, May 23, 2004 at 15:08
You never know whats in the garadge John lol .
FollowupID: 321381
Follow Up By: Willem - Sunday, May 23, 2004 at 17:44
Hello John
Electric toothbrush????? Nah, not for me. Not enough teeth left.
Your ship has already come in.....!
BTW I tried the phone out ...and it works!!!
G'day Eric,
Anything interesting in your garage for me? (like 1500 watt inverters)...or .....now let me think...what do I need? Ah! a spare G60....lol
FollowupID: 321403
Follow Up By: John - Sunday, May 23, 2004 at 19:02
Of course the phone works, I wouldn't sell you a bodgie.
I had it in the Toyota Landcrusier club newsletter which only just came out and have had 16 genuine calls about it from as far away as the NT.
I think I sold it to cheap. LOL.
Actually I think my ship sunk and it's to deep for even me.
As for Nitros garage stand in line.
FollowupID: 321416
Reply By: Truckster (Vic) - Sunday, May 23, 2004 at 12:42
Drivers side would be good, helps you when reversing..
Lights on the back of the car has to be wired into the reversing lights to be legal.
AnswerID: 59782
Follow Up By: John - Sunday, May 23, 2004 at 15:13
Good point Truckster, As for wiring to reverisng lights etc.
Nah ! I don't think so, I am going to wire it to switch up on the dash so I can turn it on if I need more light for reversing or whatever so if the cops want to make an issue about it then I will tell them it does not work.
By the way happy Birthday for the other day.
Did you get a new Toyota by any chance, we still need one to come back our way since Nitro Eric defected to the other side.
FollowupID: 321382
Follow Up By: Truckster (Vic) - Sunday, May 23, 2004 at 17:52
yea wouldnt mind a switch for mine for when some prick is high beaming you from behind, would be a wakeup call eh!
LMAO
FollowupID: 321404
Follow Up By: John - Sunday, May 23, 2004 at 18:59
That was the other reason for setting up the light with swith up front.
Great minds think alike.
FollowupID: 321414
Follow Up By: Member - Roachie (SA) - Sunday, May 23, 2004 at 21:00
Blokes,
I've got the 2 little wuzzy spots on the back of my roof rack wired up to a on/on (SPDT) switch. When it's it's in it's normal position, the lights come on when I select reverse. When I throw the switch, the lights come on as well as a small green flashing LED to let me know they're on.
I have also used them for high-beam dipsticks behind me; but I'm always just a bit worried in case the driver of that car happens to be a member of the constabulary!!!!
FollowupID: 321427
Follow Up By: Truckster (Vic) - Sunday, May 23, 2004 at 23:01
Young bloke back home many yrs ago, setup 2 spotties behind the grill of his dads car, with blue and red that crinkly plastic rapping stuff, and a flasher can so they would flash.. He then went and terrorised the shagging strip up the point, until he pulled over some undercover cops lookin for him..
FollowupID: 321453
Reply By: Alex H - Sunday, May 23, 2004 at 16:27
The only dumb question is the one you don't ask
Alex
AnswerID: 59793
Reply By: Truckster (Vic) - Monday, May 24, 2004 at 16:54
You are lucky it was given to you!
They are $130ish! Worth about $30....
I had one made up BY AWILL4X4 Brilliant little unit!
Andrew is a very handy man to have on side!
Another view of it off the car...
SIMPLE UNIT! took literally 15 mins to make (hes a bit of a fusspot perfectionist ;) )
AnswerID: 59924
Follow Up By: John - Tuesday, May 25, 2004 at 02:06
Good one Bruce, nice little unit.
By the way the Kaymar one sells for anything between $180 to $220 depending on where you get it from.
FollowupID: 321612
Follow Up By: Truckster (Vic) - Tuesday, May 25, 2004 at 09:59
Yea you would have to have manure for brains to pay $200 for a $2 piece of pipe with 2 tabs welded to it, and a $20 spotty on the top of it!
this works well!
FollowupID: 321630
