Waeco Dometic 215 ltr
Submitted: Thursday, Nov 19, 2015 at 14:16
Member - G G 4 7 W A
Has any one had problems with the Waeco 215 ltr fridge freezer maintaining temperature in the fridge part , I have the fridge set on setting 3 and it should maintain plus 2 c my fridge is all over the place +2 to +12 c and not starting up when temp is high . comments please .
Reply By: Member - Jim B8 - Thursday, Nov 19, 2015 at 21:06
I am not certain I have that model, but I reckon it is. I installed a 12 volt dc fan (120mm) inside the cabinet, and it is working much better. Jaycar sell them, the cable needs a small hole drilled thru to the back to where the compressor is. Very happy with it now. It needed a wire frame bent up to support it, I was out bush at the time and used some very second hand fencing wire. Point the fan up towards the evaporator, sit it on the vege tray lid
592917
Reply By: Member - G G 4 7 W A - Sunday, Nov 22, 2015 at 22:35
Thanks for the help I will try and see what happens
593016
