Roof Top Tents - Is the mounting Dimensions all the SAME?
Submitted: Friday, Dec 11, 2015 at 19:12
ThreadID: 131103 Views:3339 Replies:1 FollowUps:2
Gents,
I'm in the process of converting our boxtrailer to accept a RTT to it and was wondering if the bolt hole dimensions on the RTT is ALL THE SAME, no matter what Brand of RTT?
I haven't decided what brand to buy yet, but I'm wanting to make up a bracket to bolt the RTT to my trailer & I need to know if ALL RTT mounting holes are the same?
I've checked Darche and the 4WD SuperCentre (KINGS brand) RTT and it appears that the mounting is similar around the 830mm mark one way and also about 830mm the other way (square).
Would this be correct for all brands???
thanks in advance.....
rob
Cheers..... RobM
DiscoTDi for Work/Play
Reply By: Member - John - Friday, Dec 11, 2015 at 21:10
Rob, can't answer your question, but I had to alter the mounting points on my RTT and it was quite easy to do, drilled new holes as required and filled old holes with Sikaflex. Job done........ Good luck.
John and Jan
AnswerID: 593710
Follow Up By: RobMac (QLD_Member) - Saturday, Dec 12, 2015 at 09:21
Sounds easy enough, but I would have thought that these holes go through the internal frame &/or supports as they would need some form of strength, etc..... u wouldn't be able to just drill anywhere would u?
rob
Cheers..... RobM
FollowupID: 862012
Follow Up By: Bonz (Vic) - Saturday, Dec 12, 2015 at 10:13
I have an ARB RTT and the mounting holes are just drilled thru the base, you could drill them anywhere you need them.
Bonz
FollowupID: 862018
