Bathroom door
Submitted: Tuesday, Dec 15, 2015 at 20:08
Tarz p
I have a Lotus Trooper and the Bathroom door has dropped and sits in the floor one end. looks like the screw has pulled through at the other end, Does any have any suggestions as to how I get the door off to tighten screws and wheel bolts so it will be able to close. I can't get it off the way a normal sliding door comes off.
Reply By: baznpud (tassie) - Wednesday, Dec 16, 2015 at 14:00
We have a Trooper also and after travelling the
Gibb River Road the bathroom door dropped but not to the extent of yours.
The only way i could remove it to fix, was to cut a piece of the pelmet out at the shower door end, take door off which is a real juggle due to lack of space, repair, then replace the door, then a couple of thin nails and some no more nails and replace the piece you cut out of the pelmet.
A call to the factory may help with an easier fix.
Hope this helps.
baz
593867
Reply By: Kazza055 - Saturday, Dec 19, 2015 at 12:49
Reply By: Member - Ian M21 - Saturday, Jan 02, 2016 at 19:43
Had same problem with an Elite.
Replaced heavy door with a concertina door, problem solved!
594411
