Waeco Fridge Temperature Display - Faulty?
Submitted: Monday, Dec 28, 2015 at 13:05
ThreadID: 131219 Views:5250 Replies:2 FollowUps:0
Hi guys,
We have a Waeco CF-35AC VERB fridge freezer that has a problem with the temperature display, and I can't find any solution in the manual or online.
The fridge is set to run at +3 degrees, and appears to be operating at about that temp, but the display is showing either -18 or -19 degrees. Note that the lowest temp you can set the freezer to is -18, so I don't know how it can display -19.
Waeco are closed until Jan 4th, so no help there.
Can anybody suggest a solution, please?
Is there some sort of reset button?
Hope someone has some ideas.
glids
Reply By: Notso - Monday, Dec 28, 2015 at 15:08
Probably the only way to reset it would be to disconnect it from the power supply for a few minutes.
It might work if it was caused by a temporary glitch in the system.
AnswerID: 594235
Reply By: D-MaxerWA - Tuesday, Dec 29, 2015 at 22:14
You are probably getting the reading from the freezer section
D-MaxerWA
AnswerID: 594286
