100 series won't turn right
Submitted: Monday, Jan 11, 2016 at 20:12
ThreadID: 131330 Views:4372 Replies:8 FollowUps:3
Hi all ,wondering if someone could help with a problem we have with our 100 series landcruiser , live axle 4.5 petrol and today I was turning around in our yard and I couldn't turn right . Turned the wheel completely to the left then back to the right and would not turn past straight ahead, any clues? Thanks
Reply By: Life Member TourBoy, Bundaberg - Monday, Jan 11, 2016 at 20:21
Busted CV, unless you have adjusted your steering box too tight recently
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 594743
Reply By: rumpig - Monday, Jan 11, 2016 at 20:35
Do they have a steering damper on them? (i assume so)...i squashed one years ago on my Hilux and had the same problem, nearly hit a power pole as i turned at an intersection due to that.
AnswerID: 594744
Reply By: Member - tazbaz - Monday, Jan 11, 2016 at 21:11
Always better to turn left than to turn right
AnswerID: 594745
Follow Up By: Zippo - Tuesday, Jan 12, 2016 at 14:23
Tricky at roundabouts though.
FollowupID: 863340
Reply By: skulldug - Monday, Jan 11, 2016 at 21:11
Judy and Laurie,
Don't leave home otherwise it's 25,000 km anti-clockwise around the block.
Sorry. Couldn't resist.
AnswerID: 594746
Follow Up By: Member - Judy and Laurie - Monday, Jan 11, 2016 at 21:17
That's ok gave us a bit of a laugh , we have done some searching and it looks like it might be the steering box.
FollowupID: 863310
Reply By: Member - mechpete - Monday, Jan 11, 2016 at 21:31
jack it up an disconnect the steering from the wheels
check if the wheels turn freely if they do then you have a problem stg box .
if they don,t the problem is in the swivel point bearings
mechpete
AnswerID: 594749
Reply By: Phil B (WA) - Monday, Jan 11, 2016 at 21:40
I have an IFS model - I had similar probs before Xmas - found it was a steering rack problem - big dollars around $2000 to fix.
AnswerID: 594750
Reply By: Member - Judy and Laurie - Tuesday, Jan 12, 2016 at 08:37
Thank you all, we found it was the steering box, so lucky we had a spare in the shed (as you do) so we changed it last night , will test run it on my way to work today ,
Cheers Judy and Laurie
AnswerID: 594762
Follow Up By: pop2jocem - Tuesday, Jan 12, 2016 at 10:34
Well there you go, a simple mechanical fix.
And here's me invisaging the vehicle in a previous life, a car pool unit owned by the Labor Party.
Kidding of course....LOL
Pop
FollowupID: 863327
Reply By: wholehog - Tuesday, Jan 12, 2016 at 23:30
"a problem we have with our 100 series landcruiser , live axle 4.5 petrol"
2 different chassis and steering box/systems. It ain't difficult.
A 105 is a live axle, recirculating ball steering box, a 100 series is independant front suspension and a rack and pinion steering system.
AnswerID: 594804
