Troopcarrier problem .
Submitted: Monday, Jan 25, 2016 at 14:37
Member - mark D18
Seems there are a few members out there with Troopies.
I have a 1999 75 series with 248,000 km and in the last few months it has developed a soft low pitch whistle at between 16 hundred and 2000 revs in 1 2,3,4 gears ( maybe gearbox ? ).
Apart from that the gearbox and transfer case work
well , with no obvious problems
I know it may be a difficult problem to diagnose , any ideas would be appreciated .
Reply By: Member - Andrew & Jen - Monday, Jan 25, 2016 at 14:51
Hullo Mark
Might be worth while having a look at the lcool site. (lcool.org)
There is a section for 70 series Cruisers
Only takes a short while to join (free) and you can tap into a group of very knowledgeable people
Andrew
595402
Follow Up By: Member - mark D18 - Monday, Jan 25, 2016 at 15:03
Andrew and Jenny
I have had a look there as
There a few guys on this
forum who seem to have good knowledge in regards to old Toyota's.
Thanks for the assistance
864100
Reply By: Life Member TourBoy, Bundaberg - Monday, Jan 25, 2016 at 17:38
could be a restriction of some sort in the exhaust, can cause a whistle at certain revs
595405
Follow Up By: Member - mark D18 - Monday, Jan 25, 2016 at 17:48
Thanks Tourboy
I Just put on a near new exhaust from my mates new Land cruiser ute ( he installed a 3' exhaust )
But I suppose it could be in the old front section .
I will suss it out.
864104
Follow Up By: Malcom M - Wednesday, Jan 27, 2016 at 07:55
Did it whistle before you swapped out the exhaust?
864181
Reply By: 2517. - Monday, Jan 25, 2016 at 21:25
Transfer case more then likely case hardening has came off bottom sharft and gone through box,very common.
595410
Follow Up By: Member - mark D18 - Tuesday, Jan 26, 2016 at 13:58
2517
I would have thought that if it was the transfer case than the noise would occur all the time, not just at about 1800 revs.
864150
Reply By: Michael A (VIC) - Monday, Jan 25, 2016 at 22:44
Try Troopcarriers of Australia Facebook page. I have had plenty of input/ideas for my Troopy
595419
Reply By: Member - Alastair D (NSW) - Tuesday, Jan 26, 2016 at 06:30
Mark,
You say whistle so I am thinking it could be a leak in the exhaust/manifold. Have you disturbed anything associated with the exhaust recently? Look around the manifold and especially where the exhaust pipe comes off. They do tend to crack the weld around the flange if the support brackets have not been set right.
If it is more a whine then there is a
well known problem in the gearbox/transfer which is much discussed on LCOOL. If you think it is this then do something soon as it gets more expensive if left.
595424
Follow Up By: Member - mark D18 - Tuesday, Jan 26, 2016 at 13:20
Alastair
Have just put on a near new exhaust from my mates new cruiser ute , I will get under it today and have a look
864149
Reply By: sweetwill - Tuesday, Jan 26, 2016 at 08:10
Morning Mark.
My 80 serise aquired a whistling sound in all gears when driving and it turned out to be the ribbed fan belt, happy Australia day Mate.
595426
Reply By: nickb - Wednesday, Jan 27, 2016 at 02:04
Did the noise only start after the exhaust was done?
Is yours turbo?
Could be the sound of the turbo, quite often the whine becomes noticeable after adding a
snorkel or free flowing exhaust.
595468
Follow Up By: Member - mark D18 - Wednesday, Jan 27, 2016 at 08:18
Nick
No it has not got a turbo
And yes I have just put on a near new back section exhaust on .
I am going to drop the transfer oil today and have a look for any silver oil .
864183
