Coleman folding chairs
We have a perfectly good relatively expensive camp chair, which has been hardly used but one of the plastic feet have broken and Coleman don't sell replaceable ones. Does anyone have any ideas for replacements other than buying a new one for spares?
Reply By: brianH - Thursday, Jan 28, 2016 at 19:30
If you have your purchase receipt and the chair is less than five years old you may be able to get a refund. hope this helps, Brian
AnswerID: 595559
Follow Up By: Shaker - Thursday, Jan 28, 2016 at 19:55
Do Coleman have a 5 year warranty?
FollowupID: 864263
Reply By: Fulwood - Thursday, Jan 28, 2016 at 19:38
Thanks for the reply but they are 7 years old
AnswerID: 595560
Follow Up By: Idler Chris - Thursday, Jan 28, 2016 at 20:21
Count your blessings you are lucky it lasted that long.
FollowupID: 864266
Reply By: Member - mechpete - Thursday, Jan 28, 2016 at 20:30
common problem ,
that's why I replaced my last chair
mechpete
AnswerID: 595562
Reply By: Idler Chris - Thursday, Jan 28, 2016 at 21:32
Look at the feet on the most expensive chair and compare it with the cheapest chair, they look the same to me.
AnswerID: 595566
Reply By: eerfree - Thursday, Jan 28, 2016 at 21:51
Fulwood,
Front or Back leg, I have some spares, yours for cost of postage, they are used but better than broken.
email Randla at westnet dot com .au
Bob.
AnswerID: 595568
Follow Up By: Fulwood - Friday, Jan 29, 2016 at 00:03
Sounds great. I will email you
FollowupID: 864274
Follow Up By: eerfree - Friday, Jan 29, 2016 at 00:20
Fulwood,
That email addy is all lowercase.
Bob.
FollowupID: 864275
Follow Up By: Fulwood - Friday, Jan 29, 2016 at 10:21
Thanks. I have sent u an email. Let me know if u didn't get it
FollowupID: 864278
Follow Up By: The Explorer - Friday, Jan 29, 2016 at 18:10
FYI....an email address can be portrayed upper or lower case (or mix) - it makes no difference - it will still be sent to the same address. e.g. JOEBLOGGS@XYZ.NET.AU = joebloggs@xyz.net.au....or any other combination of upper and lower case you would like to use.
FollowupID: 864304
Reply By: Member - Scott M (NSW) - Friday, Jan 29, 2016 at 10:35
I tend to find those chairs with the multi point feet tend to break over time. The only advantage is they can be folded fairly compact.
If you have the room to lie flat, the ones with the single cross leg are far more robust.
AnswerID: 595577
Follow Up By: Gronk - Friday, Jan 29, 2016 at 15:12
But the directors chair is nowhere near as comfy as the top chair.
My latest chair similar to the top one is a steel frame one ( a fair dinkum 150Kg's ), and it looks to be surviving a lot better than the last 3 similar ones I had ( aluminium frame )....it's now 2 yrs old !
The weakest point on all the ones I've had is the material "eye" just down from the front of the armrest. Me being 110kg doesn't help either !!
FollowupID: 864294
