jackaroo diesel 2000 coolant radiator leak...which hose?
Submitted: Friday, Jan 29, 2016 at 02:04
ThreadID: 131482 Views:3036 Replies:2 FollowUps:1
Hi...new to.this but hopingsomeone could help?my lovely 4wd has a leak by the exhaust section.that goes up below.drivers side dash...it can only be seen.from.below.theres a clamp its quite high up.and about an.inch wide.as the leak is low...the car doesnt run
Can.anyone tell me.which hose.it is.and.how.to.get to.it?many thanks
Reply By: Member - John - Friday, Jan 29, 2016 at 10:14
This should be in the Friday Funny thread................ More information required, if car doesn't run, I think it may need more than a leak fixed!!!!!!!!!!
John and Jan
AnswerID: 595575
Reply By: Tim H14 - Friday, Jan 29, 2016 at 22:47
It,was hose going to oil pressure caused air block no fuel going cost 400 just asked if anyone knew what that hose was for its ok now just cost a bit to fix
AnswerID: 595633
Follow Up By: Colcam42 - Monday, Feb 01, 2016 at 13:36
Hi Tim, My mate had a Jackaroo and similar trouble several times. I believe that it was to do with the fuel pressure regulator, it uses oil pressure to control the fuel rail pressure. Make sure that you only use the specified engine oil viscosity as this can have a profound affect. Also, the regulator apparently gums up, causing hard/non start, a replacement is around that price range but we did once find a Google link about stripping it and cleaning it out.
FollowupID: 864482
